New here, thanks for letting me join.
Go to solution Solved by aefron88,
  • Solution
you may need to adjust it wears they are not self adjusting like on a car. theres a bolt and locknut on that center caliper.
With the parking brake released, loosen the locknut and tighten the bolt with your fingers till sung, then back off a turn, and tighten the locknut. Check that the parking brake pedal doesnt bottom out, and you dont get any squealing when driving or you may need to re-adjust.
  • 6 months later...
Yep, that was it.  There is so little range of movement on the E-brake lever that this adjustment has to be "just so" in order for it to brake properly but not drag when released.  Some kind of lever operated internal cam squeezes the caliper but very little range of movement.   Thanks for that heads up..
    • By SkyPilot56
    • By Aaron Colona
    • By GunnersTacklebox
    • By ToughLuck
    • By CapnWalleye
