you may need to adjust it wears they are not self adjusting like on a car. theres a bolt and locknut on that center caliper.
With the parking brake released, loosen the locknut and tighten the bolt with your fingers till sung, then back off a turn, and tighten the locknut. Check that the parking brake pedal doesnt bottom out, and you dont get any squealing when driving or you may need to re-adjust.
    • By JSwearer
    • By Howard Elmore
    • By A P
    • By Will Sutton
