please help somebody. if anybody could take a picture of their fuse box under the dash of how the fuses line up or what amp fuse belong where i would greatly appreciate it. i finally got smart and pulled all my fuses out, cleaned the terminals and applied dielectric grease. but got real stupid and forgot how they go in..or what goes where...please help. it's a 2009 trooper t2.
thank you,
randy
thank you,
randy
Hi, mine is 2008, But it has schematic on inside of cover, might ck?
thank you,
randy
OK, this should get you out of trouble. The front fusebox has 3 relays and a larger relay for the turn signal. Along side of them are the fuses. Starting from the side with the larger flasher relay, the first fuse is orange (5A), then brownish (7.5A), brownish, blue (don't know), orange, orange, orange, brownish. Hope this helps.
Hey thanks Lenny, that was it. I appreciate you taking the time to post this for me. you da man!
Randy
    • By Xov
    • By Marie
    • By rdborra
    • By carl baney
