800sx dump box extends how far beyond tires?
By doncaron
Hello
I have a 2022 Massimo t-boss 550. I’m looking for a fix for my timing problem. It keeps getting out of timing. Now I’m trying to find the proper parts for the linhai motor. I’m looking for tensioner chain and gear. If there’s anything else I can do to fix this issue please let me know. Unfortunately I can’t afford to get something better so I got to get it fixed. Thanks in advance.
Don
By NHTracker
I have 2020 Tracker 800SX LE that I bought new in 2020. Yesterday i noticed two cracks in the bed in the corners at the tailgate end. They go all the way through the bed. I use it around the property moving firewood, dirt and stuff. Don't know how they could occur. Has anyone else had this problem? Is there a fix? Help!!!
By Pilot1996
When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
By Alien10
