Mule alternator?
By Greg Kilgore
By rsar
By Eagle Mountain Outfitters
Our R&D team just finished the first unit and wanted to show you guys. Need more cargo space without losing the functionality of being able to fold down the seat to use the full bed? Eagle Mountain Outfitters, the maker of the original metal UTV roof, has designed a foldable rear cargo basket to meet your needs. Price is $625 + $30 shipping. If you have any question's, please reach out to me at [email protected]
By Kingfish
Register a new accountSign in
