WHAT’S NEW FOR THE YAMAHA RHINO
Yamaha Rhino 660 6 Over Long Travel Kit
Made for the desert and the serious off-road racer, DragonFire Racing’s new 6 Over Kit is 4130 tube and plate. It is all Tig welded, the upper A-arms utilize hiems for final adjustment, the rest of the suspension is bushings and crush sleeves. [...]
View the full article
    • By D MAYNARD
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By bms stallion owner
    • By SpaceGhost
