I ordered A enclosure from Brostar and what a difference it has made. It is much more enjoyable to ride in the cold. Now I am ordering a heater to complete that part of the project. Next year I hope to get some tracks and make it a true go anywhere any time machine. This is truly an awesome toy.
Todd
Todd
What are you ordering for a heater?
Kinarfi
    • By rev6engines
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By mark walkom
    • By Kingfish
    • By Woody77
