By
Xov
Fire mitigation / slash removal from a 5 acre forested and well-gamble-oaked property. The previous owners thought as much about fire mitigation as I do about fashion: not much.
Snow removal
Stump pulling
General hauling (rock, lumber, etc.)
Weimaraner energy depletion. Wasn't an original use case, but a nice added bonus.
Experiences So Far
