Just pull the cover off the drivline to the front / the shifter cover. The bearing is between the seats. I had to remove the grease fitting and add a 90 degree elbow. No way could I get a grease gun to the fitting.
rocmoc n AZ
    • By D MAYNARD
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By Robbie Wyre
