I am taking pics.
You will need -
Two rear wheel bearings, I got mine from snowman at No Limits Powersports, http://www.joyner-atv-utv.com/ but also available from Silver Bullet Motorsports, http://silverbulletmotorsports.net/
Two seals (metric sizing), part specs TC 45 65 8 purchased from Motion Industries, http://www.motionindustries.com/motion3/jsp/mii/LocationsMI.jsp which are being dropped shipped to me. 3 for approx $15
Large socket set to break the nut loose on the axle holding the hub on. I have a 3/4" set and worked great.
C-clip removal tool, I have one but was easier using an old screwdriver trick.
Seal puller, I have a bodyman's dent removal tool with an adapter that works. This saves the old seal but you could use a screwdriver and kill the seal.
Remove the wheel/tire.
Remove the cotter key.
Remove large nut, someone needs sit in the Trooper applying the brakes to keep the axle from turning.
Remove the brake calipers, 2 bolts per caliper & two calipers per wheel in the rear for a total of 4 bolts.
Slide the hub & rotor off the end of the axle.
Remove the 2 bolts holding the backing hub/bearing housing to the swingarm. One on top, one on bottom.
Remove the bearing housing.
Wipe, clean so you can see what you are doing.
Remove the seal. The seal is in front of the C-clip & bearing.
Remove the C-clip, can be a pain if you have never done it before.
Slide the bearing out.
CLEAN!
That is as far as I am on one side. Waiting for the seals. Why there are seals is beyond me. The bearing is sealed so it is just extra protection. There was grease in the area between the seal & bearing. Cheap insurance so I will put it back the way I found it. I can tell the bearing has spun a very very small amount. The fit between the housing & the bearing is still very very good. Lenny's tip to locite the outside of the bearing in place to the housing is important! But will make it more difficult to remove the bearing the next time it requires replacement.
Yes, my original bearing had wear & slop. IMHO not that bad but did need replacement. The bearing isn't as bad as the design of the housing is. Taper roller bearings should have been the real design but what the heck lasted 4 years.
rocmoc n AZ
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
I am taking pics.
You will need -
CLEAN!
rocmoc n AZ
Thanks rocmoc,hope kinarfi puts this in a folder for future reference.
I am taking pics.
You will need -
CLEAN!
rocmoc n AZ
When it comes time to remove the loctited in bearings, just add some heat, about 200 degrees and they will come right out. Wouldn't hurt the bearing either but you wouldn't be removing it, if it was good anyway. Sorry I didn't get to your emails sooner, switching to a new computer and it's not plug and play to move everything over and get it all working.
I am taking pics.
You will need -
CLEAN!
rocmoc n AZ
Mr. Rocmoc,
Do a good report on this, I plan to just copy and paste your report into Parts, pieces & info. Unfortunately, that post is getting so big, I think I need to break it up a little, so this will be under the heading of rear wheel bearing replacement by Rocmoc.
Kinarfi,
Will do, that is what I am trying to do. Not everyone lives near a great dealer/vendor like the ones mentioned above for parts so they are on there own. Hopefully this will help them order and install themselves. There are always little surprises in every task and that is what I will try to eliminate.
rocmoc n AZ
Kinarfi,
rocmoc n AZ
Looking good so far, we can put all the photos in web shots and thumb nail a few of them into the post. This would work for other projects also, Maybe when I get enough courage to pull my engine and rewire, I'll post that there also. A report on differentials would be good too, maybe on CVs.
kinarfi
I am taking pics.
You will need -
CLEAN!
rocmoc n AZ
Silverbullet hi rocmoc
We Just got are double row taperd roller bearing.Made in the UK. 35x65x35. these are vary good quality.On the subject of any bearing they should be clean and greased 1 a year.Sand can get in or water also.We recomend this to all our customers.The seal cant keep the bearing clean.We check all our bearing to make sure they are greased from factory.Some bearing have little grease in them when new.
Hope this helps you guys and no cotter pins, use some thing made out of steel.
I use a nail as the cotter key. Works great and is cheap. Yearly is too much work vs reward for me. It is like the people who change their oil every 3,000 miles. I change mine every 15,000 miles. Originals Joyner bearings lasted 4 years. I would be more concerned if I played in a lot of mud & water and that going to happening here in So. AZ. This is the same style bearing ran in the rear of BMW and they don't have the additional seals, only the seal on the bearing. The bearings in the BMW are normally good for 60,000+ miles but the quality is the big question. Thanks for the info & advise.
rocmoc n AZ
Surprise, surprise, surprise. I did the easy one first. Everything was the same until it came time to remove the bearing. This one was tight / press in. It was more of a challenge to remove the bearing from the housing. This is the way they are suppose to be, my left side is a very very small amount enlarged. Not a problem yet but something to watch in the future. That is why the outside of the radius showed it had spun. The real design flaw is the housing. It should have been a bit larger so it could have held a standard 35 72 35 bearing. MAYBE someday if a new part is made Joyner or aftermarket why make this correction, a very easy fix with NO additional expense if done at the time of manufacture. In the next post I am linking TWO youtube videos of the rear bearing replacement on a BMW. The process is nearly identical. The bearing is identical but a std size, humm the Germans have there act together.
rocmoc n AZ
Seals arrived. Timken 45X65X8 / 100127598 / 1.772 X 2.559 X 0.315
Motion Industries charged me $11 for 3 seal and $12 shipping plus tax for a total of $25.05 for 3 seals. Do a search on google and see if you can get a better price. Seems high to me!
Still healing!
rocmoc n AZ
I cleaned parts today.
The seal info above / earlier is for the outer seal. There is an inner seal and the numbers to use for replacement are TC 42X62X8. I did not remove mine as they do not inhibit the replacement of the bearings and were in good shape. After cleaning I could see the number for future use. Since I removed the entire hub / housing, I took the opportunity to clean the two bushings contacts. Both were in good shape and will be greased when reinstalled.
rocmoc n AZ
rocmoc n AZ
I hope you are taking pictures.
As it turns out the process is EXACTLY like the youtube videos I posted with the exception you take the hub / housing off. You do the same removal & install of the bearing on the bench or floor. BUT the exactly same process, EVERYTHING!
We do have the addition of the inner & outer seals but that is a very minor item to deal with. Very easy to remove & install.
rocmoc n AZ edit, kinarfi, 10-4
DONE! The process IS exactly as the BMW youtube videos. All of the components look nearly exactly the same except in size.
Key Learning of Bad News & disappointment:
The bearing HAS TO press out and press into place. If you can remove the bearing with your fingers or will little effort, the hub / housing is SHOT or needs rebuilt. After putting everything back, using loctite and torquing the nut correctly; the left wheel still had slop / movement. Definitely, IMHO, the bearings are of much better quality than the hub / housing. So now I have to keep a look out for a replacement hub / housing or see if an aftermarket source can be found. Replacing with the same IS NOT the real fix. That will only a band aide as it is just the same thing that has already failed.
Right side, bearing had to be pressed out and pressed in, came out perfectly!
If you are replacing your bearings and the wheel as slop before you even start, be concerned. If you can remove the bearing with little or no effort, you are wasting you time & money!
rocmoc n AZ
rocmoc n AZ
Glad to hear your feeling better.Hows the better half doing? Maybe some fresh air in Havasu this weekend will do her some good(LOL)
She hasn't got to the point of recovery yet! I am only back to bouncing between 80 to 90 percent. I just wanted to get the Trooper finished and see the results. And it is Freakin cold here. It was only 37 degree at 11am.
rocmoc n AZ
rocmoc n AZ
Theres many other parts of the country that would love to have it that warm.Hopefully Lenny doesnt kick in here and call you that name again.what was it?????(LOL)
  • 4 weeks later...
I am taking pics.
You will need -
Two seals (metric sizing), part specs TC 45 65 8 purchased from Motion Industries, http://www.motionind...LocationsMI.jsp which are being dropped shipped to me. 3 for approx $15
CLEAN!
rocmoc n AZ
I'm doing my wheel bearing and your write up is good but you left one thing out and that is it takes a 36mm socket to take the nut off
Sorry about that! You need a 36mm socket OR a 1 7/16" socket. I used a 1 7/16" from my 3/4" drive set. I used a huge pipe wrench to hold to axle while I torque the nut if you are doing a one person job.
rocmoc n AZ/Mexico
rocmoc n AZ/Mexico
Well we only expect the best from a person of your cailber
Sorry Rocmoc, you don't get paid any more then before but you do get a more important sounding title.
    • By Wolfpaak
      Kenny
    • By Grant
    • By Tejun
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
