Trooperfolk, when posting on webshot, may I suggest, ask, that each of us create one album for ourselves and then just keep uploading to that one album with our own name on it instead of having several separate albums. If you still have all you photos, you may even want to consolidate your albums into one.
    • By BMurph
    • By Jacob E freeman
    • By Kingfish
