Fuel pump failures
By rsar
By TjB
My dad has recently acquired a 2510 Kawasaki mule Diesel powered. It worked fine few weeks and then quit driving. Put a new belt on just to see. Still not driving. It already had a new clutch. Belt turns when in drive or reverse and back wheels are off ground to test. But wheels not turning. Thoughts?
By Will D
Hello, I have a mule 4010 trans that appeared to overheat based on the temperature light on the dash and it went into limp mode. No steam though. After letting it cool and the next day, I drove it around quite a bit and it did not have any problems. Any ideas on this. Do thermostats work intermittently? I would like to fix the problem, looking for advice. Many thanks
