I took in my UTV and they fixed the no power I was having ( broken  ground wire)  but they told me I would need a new turn signal relay . If you use the left or right turn signal you get a high pitched whine . I need to look to see if the lights blinks but I don't believe it does. I thionk the relay is located in the battery box with the fuses and starter solenoid. Where might I find a turn signal relay . I have done several searches but come up empty . Anyone have this problem before or know where I might purchase a relay ?
Any flasher with the same number of poles will work. I believe it is a two pole. I replaced the one on my Massimo 700 (same thing) with one that didn't beep. If you want one that beeps like the original, check out the motorcycle doctor on ebay.
Could you take a picture of your relay and where it is located in your UTV. Even if I can find a replacement  I'm not sure where the relay is. Or if anyone with a working turn signal can post a picture of the relay in its correct position that would help immensely.
Super easy fix . I uploaded a picture of the battery box with the turn signal relay marked with a blue arrow. The next picture is form Amazon where I bought a $11 part . I unplugged the old relay and installed the new one in maybe 30 seconds. Now turn signals are fine and I have the option of speeding them up or slowing them down . Problem solved .
    • By klm
