In the market for side by side. Narrowed it down between the pioneer 1000 or defender Hd9. Looking for pros and cons of both. Any info would be helpful in my selection process. Noise, speed, reliability, ride, all of it.
Honda. Not even a question. Especially for reliability. It may not be the fastest or smoothest but it won't leave you on the trail stranded. No belt to break. Real transmission and gears. Every oil change also changes the trans fluid as they run in the same fluid. I had a pioneer 700 and it was amazing. Now have a talon. Never any issues on either aside from maintenance. Just my 2 pennies as a 24 year veteran mechanic.
I do all my own services end repairs.
But the B.U.D.S system from BRP is a crime. Have an can-am ATV and a skidoo snowmobile, both standing still because I can't read the ECU.
Had a lot of silly troubles with the ATV from new. Not nice to standing in the middle of nowhere and the thing will not start. And suddenly after a few minutes is starts like there was nothing happened.
Never a BRP product for me again.
edit: I wrote DESS intead of B.U.D.S.
Honda is a well-made machine as most all of Honda products, but I'll warn you that the cab in the P1000 gets hot from the engine heat. If yd need a windshield, make absolutely sure you can open part of it for much needed ventilation.  Can Am did have a reliable rep when I was shopping 5 years ago, but Honda rep can't be beat.  Polaris has many more machines on the road (trails), more dealers, and more accessories available.   I own several Honda machines including a P1000 primarily because they just keep running year after year.
The P1000 is not sporty, but it is a great workhorse that you can certainly use on the trails.  It has plenty of power.  I don't think you need the paddle shifting unless you're really into "playing" in the dirt which some people seem to enjoy.
    • By Unhappy Kioti K9 Owner
    • By Blair
    • By ToughLuck
    • By Steve Waldner
