SPARK PLUGS FOR TROOPER
By Browner010
By Robby
By Greg Kilgore
By Jhud
In the market for side by side. Narrowed it down between the pioneer 1000 or defender Hd9. Looking for pros and cons of both. Any info would be helpful in my selection process. Noise, speed, reliability, ride, all of it.
By Joe Breaux
Everybody out riding? Awfully quiet here recently. It's so damn hot here .We expect 112 to 116 heat index tomorrow..getting too old for that heat.
