Do you wear a helmet when riding your side-by-side UTV?
By CSM_Retired
This is for all of you Kioti Off-Road UTV, SxS (Side by Side) owners. Discussions about Kioti Off-Road specific topics including the Kioti Mechron, K9, 2400, and 2440 models.Â
Is there a code reader available for the Coleman UTV 400? I tried using the HUD ECU Hacker software and cables/adapters but no luck OBD to delphi 6 pin and KKL VAG as well as ELM327. Will not connect. I was able to get it to connect randomly a couple of times, but haven't been able to since. I was able to clear and read the codes briefly. I'm aware of the Tiny Scan 301 but it doesn't seem to be readily available. There's a few out there but they are expensive. Â
By FTG-05
Â
Could someone please recommend a reputable shop to troubleshoot and repair a Coleman UT 400 in the DFW TX area? Â
By bms stallion owner
