By
10point
Hi Out there in UTV land .
I am attempting to repair my buddies Massimo 400 he bought new from tractor supply in 2011.
Before I make the repairs I am trying to locate a service repair manual that covers a 2011 MSU 400 carbureted, (NOT EFI).
He has done few repairs and only changed oil on occasion. LOL
It has so many issues it hard to know where to start. The big issue is when its warm it refuses to start unless it cools down to cold.
Other wise it acts like its flooded, I have checked for spark when it doesn't start and that's good.
First when I brought it home it needed a good power washing ,so I could actually see the power train,
I removed all the belly pans, also to replace the park brake cable, which has not arrived yet.
My next step was to locate a missing shifter cable bracket bolt , the bracket was moving and not allowing to shift into reverse.
Its much better, but the shifter lever bushing are so wore its still causing a cable travel issue that I need to fine tune.
The front axle bearing are loose and the RF caliper is hung up .
So I ordered the rear center caliper and the 2 front calipers with new pads, and the 2 front seals and wheel bearings,all from E bay.
Hoping I can clean up the discs instead of buying new , limited budget and he only runs it around his property.
Currently I am making a list of the original fuel lines and vacuum line, what a maze those lines are.
I would buy them from Massimo, but all there items are out of stock, 14 days at the earliest., besides the don't list fuel and vacuums lines,
Some fuel lines are smaller on one end and much larger on the carb bowl.
I am doing this as a favor because it was just sitting in his shed, and he has done many favors for me in the past and is the best hunting buddie anyone could wish for.
So I really want get his UTV operational again, I have been researching for 2 weeks off and on , wish I would have got on to this site the first night,
Hope someone out there has some positive news about a manual.
I contacted the UTV guy on eBay 3 times as of tonight he has not given me an answer on the years covered for the manuals he has listed .
So far in the time I have been search , think I would buy another brand, the parts seem hard to find .
Thanks for reading ,
10 Point
