Bighorn 400cc jerking acceleration
By Qtband
I'm looking at picking up this UTV and this is what the owner says:
"All I know about it is it runs. Display does not work and it will not move! Front end or trans could be locked up. It moves some, but does not sound good."
My question is, what could the moving issue be, and how can I check it out when I look at it? I feel the price is right at $2000, but I'd like to know what I'm getting into.
By Toofast4you
I have been working on variations of the Clutching for the 6 Arm design and have had Outstanding results . The Test vehicle is a 21 Turbo RR completely stock. All changes are in the Primary Clutch . The 6 Arm clutch made more power than the P Drive (stock) after the 6 Arm was properly calibrated. Here is the final Dyno pull . This is the stock clutching vs. the Prototype Kit . Very Impressive ......Just wanted to show that you can get plenty of performance out of the 6 Arm clutch and not buy a P Drive . In Fact , i tweaked a P Drive and The Graph was almost identical when both clutches were ran ....Both of these clutches were ran on the same machine ....
By Dan Jumper
Does anyone happen to know if the wires in the glove box are for a trickle charger? Black/red wire with connector at the end, normally to connect a charger but just wanted any input. Don't want to fry anything.
