Joyner Ball Joint Modified by Silverbulletmotorsports
By Xov
By FTG-05
By ned
I have a Kubota RTV -X900 that I recently got from someone that is in good condition. I'm trying to determine what year it is all to no avail. I have the 16 digit product identification number and have gone on line to multiple sites with no luck. The number is A5KB2FDBCFG024444 . I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit. Thanks in advance.
By SpaceGhost
They will be coming off.
Is there a diagram of all of the grease zerks for a Coleman UT 400? Mine squeaks like crazy and want to try and remedy it.
