This machine is in very, low mileage condition. It has only 89 original miles and 31 engine hours of use.
This machine looks great.It has obviously never been wrecked or rolled.It has no cracks in the plastics.
This Ranger is a 700 CC electronic fuel injected bike, it has a full dump bed, full roll cage , bench seat, digital gauges, perfect tires, in/out all wheel drive.
For more information and photos please e-mail me at [email protected]
    • By mark walkom
    • By Reynolds Rocket
    • By amiracle40995
    • By lmarkie
      Any thoughts?
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
