Has anyone else run across this? At the bottom of his home page says rjs supercharge kits for joyner buggies but has listed 1100cc fi trooper. Being that I like rock crawling may be a good choice. what do yall thing? www.rjssuperchargers.com
A super charger is going to give a lot better low RPM torque for rock crawling. You definetely want to use an aftercooler and the engine needs to have the very mismatched prots cleaned up. Lowering the compression is also necessary. And for rock crawling I would go to the renegade diff gearing. Contact Jarrad at No Limit Motorsports about this.
I have already talked to him today. Had to order up two outer tie rod ends and rear axel that I broke this past weekend. We touched on the topic of superchargers today said that you have alot of torque. Do you have renegade gearing?
Well who is going to be first
Yes I do have Renegade gearing and like it. I think Rocmoc is getting ready to put it in his Trooper too.
Cool. What is the top speed of yours after the gears? What size tires are u running?
I run 31x10.5-15 Mickey Thompson Baja Claw tires and my top speed is still probably 60-65. It was probably 75 with the stock diff gearing.
That diff gearing makes a big difference cause my top speed is somewhere around 65-70 On 28.5/12/14. I think it may be to low being that I only have 28.5 tires.
Register a new account
Sign in
    • By Ken rung
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By rocmoc
      rocmoc in AZ/Mexico
    • By SouthernGypsy
    • Get More For Your Device
    • By Nutcase
      I have a Joyner Trooper 1100 4 place that has been sitting for a number of years. I have everything taken care of but i can't get the fuel through the injectors. Fuel pump puts full pressure on them but they don't turn on or spray fuel. Any ideas?
