I'm looking at building a full-flow header with a cleaner collector than the one that came stock. I haven't done the math yet, but the tubes look like they are too long before they hit the collector, and they are rather poorly made. I'd like to find a flange for the header that i can use to build a header and good collector/tailpipe. Is there a good header made, or a header flange? I have the 650 two cylinder.
I know of NO aftermarket headers. I agree our header is more of an exhaust manifold than a header. The tubes on the 1100cc are also different lengths thus a poor header. A real header would also produce an entirely different sound, more like a race car.
rocmoc n Mexico
rocmoc n Mexico
I really don't know anything about headers but I do know that the header design is a function RPMs and the use of the engine. A high torque low RPM header is going to be different then a high RPM high HP header. I did run the numbers on the intake tubes at one point and came up with, if I remember correctly, about 3/4" ID for a naturally asperated engine of our cc's for max HP, can't remember the best length, but I feel this would be detremental to low end torque. I assume that the sound of a high torque low RPM header will sound sort of, how do I describe this, PUTTY sounding with putts that are real hard hitting while I think of a high HP higher RPM racing header sounding like Rocmoc says, a smooth very consistant from cylinder to cylinder buz. How do you describe a sound? Cleaning up the ports would be my first step but then again that is part of building a good header. The port passages in the head itself can be also improved but you must be very careful to not cut through into the coolant chamber.
I know of NO aftermarket headers. I agree our header is more of an exhaust manfould than a header. The tubes on the 1100cc are also different lengths thus a poor header. A real header would also produce an entirely different sound, more like a race car.
rocmoc n Mexico
Hi Romoc we have found that the stock cast iron manifold puts out more torque on the lower end than the header. Just something to think about.
Silverbullet
Silverbullet
Do you have any stock manifolds for sale?
I don't have the four cylinder, I have the two cylinder. The pipes are OK from the head, as far as i can tell, but the collector looks like booger welds, as does the turnout to the muffler. I'd like to start fresh, it is easier to get clean welds on fresh metal. The tubes are long enough for good torque, I just want to get a clean exit.
Hi Guys
All 2011 Troopers will come with the cast iron manifolds.We are trying to get them but China Joyner is not being helpfull.We are going to see if a header dealer will make some headers for more toque on the bottom end.Let see what happens.
Silverbullet
Should be the same process as in the articles I posted. Four or two should make zero difference. Just takes time & money, LOL!
rocmoc n Mexico
rocmoc n Mexico
LOL, both of which are in short supply....
Hi Guys
Silverbullet
Hey Rick,
I take exception to what you just said about Joyner China. The way I see it, Changzhou Joyner is contracted to JMC and can not deal directly with you even though they would love too. This doesnt make them not helpful, it means their hands are tired. Lets all just remember that the Joyner manufacturers are in no way part of what has happened in North America, period. They could not possibly foresee that JMC would simple not order units or parts. I dont know of anyone that blames them at all.
This last 12 months or so has done nothing, other than to make them more determined to make sure contractual agreements will be 100% vetted in the future. Talking out of tune Rick, when Joyner can not possible help you, will really get you in their good books aye!
I think you may of made a typo and should of said, JMC is not being helpful.
Cheers Mike.
Hey Rick,
I take exception to what you just said about Joyner China. The way I see it, Changzhou Joyner is contracted to JMC and can not deal directly with you even though they would love too. This doesn't make them not helpful, it means their hands are tired. Lets all just remember that the Joyner manufacturers are in no way part of what has happened in North America, period. They could not possibly foresee that JMC would simple not order units or parts. I don't know of anyone that blames them at all.
I think you may of made a typo and should of said, JMC is not being helpful".
Cheers Mike.
Silverbullet
On the question about Joyner not being helpful, I meant that many vendors they used were not very helpful. Yes we all know JMC is not doing its share.I was Joyner # 2 Dealer in the USA when John use to own it. I know that they have a contract with JMC and Joyner Could Not Sell to anyone else.
Rick
Silverbullet
Rick
Cool, that clears that up.
Cheers Mike.
I sent you a pm.
Hi Rick. I tried to send you a PM, but the computer said you couldn't accept anymore messages. Shipping by mail would be approximately $30. If you are interested I will need more information.
Trevor
    • By Jacob E freeman
    • By Kingfish
    • By WCF
      Hi Joyner Gang
    • By Stan Morton
      My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850.  If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance.  Kind Regards, ~ Stan
    • By doncaron
      Hello everyone!
      First of all I would like to thank you for the help with my timing problem, it was the chain. Now I’m looking for the part number for the wet clutch baring.  I’ve been looking for it but my side by side is a 2022 t-boss 550 and it’s not the same as a 2021. Can anyone help me please?
      thank you in advance again.
