Hey new to the forum, but wondering if anyone has had engine trouble (bent exhaust push rod). 2008 model with 281 hrs, dissapointed to say the least!----------------------------------After replacing most everything the fix was a new head, absolutely no help from Kawasaki Customer Service, the worst I have ever had with a company of this size. Buyer of Kawasaki products beware!!!!!!!!!!!!!!!
    • By aefron88
    • By SSgt1994
      Myron
