Hi,
New to the forum.
Came here looking for some experienced UTV users who can enlighten me about which brand should I pick for my very first UTV or SXS
I'm between 3 brands and 3 models:
*Kawasaki MULE PRO-FXR   1000.
*Yamaha wolverine rmax2.
*Can am Commander XTP.
The use I'm willing to give it is mostly to go to the range with my wife, load steel targets and all our shooting gear, we shoot a lot, rifles, Shotguns and Handguns for practice, training and competition. (Range is about 10 miles from home)
i have a kaw mule...............use it around house for hauling, plowing snow, etc.............but my mule is a 600..............no speed demon...............has been reliable (purchased 9 yrs ago), but with limited top speed, don't think it would be my choice for 10 miles drives.....agree with KLM, be ready to drop some cash, dealer access is extremely important (to me), and nothing you can buy at lowes, tractor supply, etc................good luck
  • Thanks 1
1 hour ago, T-boss 410 said:
How's your CFMoto holding up?   great  but its not a Hisun SXS now is it?😁   Its actually a very well made ATV...but not a UTV .. BTW  My wife  loves it.. 2 years, absolutely trouble free..   and its Breaux not Bureaux
12 hours ago, T-boss 410 said:
Dang spell check 🤬.
Remember, mine's a Linhai rebadged as a Massimo 😉
Linhai must be better. Sure can't be worse!! Massimo told me they dumped Hisun and went to Linhai and wouldn't warranty my Hisun motor.
I don't understand this tread.
Topic starter has three options.
Quote
8 days later, there is only a discussion about Chinese 'junk'. There is no Chinese 'junk' on TS's list.
OK, there is Chinese junk on the marked, but not everything they make is junk.
My house (and your house too!) is full of Chinese 'junk'. Look at your A-branded stuff where it's made.
Has anybody experience with Canadese junk? I do. a Can-AM ATV,  a Skidoo Snowmobile, a Bercomac Snowblower, and some Canadese bearings in Volkswagen. All very bad experiences.
But TS likes to have advice when he want to choose between, Kawasaki, Yamaha and Can Am.
My vote: not a Can Am. The B.U.D.S is your enemy if you have problems. Only a BRP dealer can help you. If there is a sensor failure, you can't find which or what sensor.
And if your (expensive) Can Am is 10 years old, they don't make parts anymore. Maybe you can find some old stock at a dealer. Than you are lucky. Otherwise you have a machine in the garage that don't run but looks as new because you took care of it 10 years.
So my vote is Yamaha or Kawasaki. Where I should prefer the Yamaha. Decent stuff at motorcycles, they know what they do. I have no experience with Kawasaki.
Good luck with you choice!
It's ok, I ended up getting a 2024 Kawasaki KRX SE.
Quote
Its hard to talk about the best without mentioning the worse.
The worse of those three TS had on the list yes,
Quote
thats called comparing.....😀
compare
[ kuhm-pair ]
Phonetic (Standard)IPA
verb (used with object)
, com·pared, com·par·ing.
  1. to examine (two or more objects, ideas, people, etc.) in order to note similarities and differences:
    If you compare these three pieces of cloth, you'll see they're all similar in weight.
    There is nothing in the definition that you should compare 3 brands/types and have to bash brands (or a whole nation) that are not asked to compare.
    @TS: Good to hear you could make a choice. Good luck with it and drive save!
Hey, I own a 2019 Massimo with a Linhai engine. This is my second Chinese made UTV, and both have been relatively trouble - free. I don't have any experience with Hisun products, just what I see here. Some have been happy with their Hisun, some not so much (such as Joe, with good reason). His issue is as much with Tractor Supply as it is with Hisun (or Massimo) for not honoring the warranty, and I get that. When you spend a lot of money on an item, and something goes wrong, you expect some sort of assistance from the seller and/or the manufacturer. In his case, he received no assistance from either.
I don't mean to be telling his story, but I definitely get why he's so negative about Massimo and/or Hisun.
I own 2 yamaha motorcycles, 2005 FZ1 and 2009 midnight warrior. The problem with yamaha is that they discontinue most models after 10 years and parts and accessories get almost impossible to find.
Haven't had any previous experience with kawasaki, this is my first time with the brand.
Quote
That's the same experience I have with BRP.
A BRP product is 2,5-3 times more expensive to buy than a Chinese equivalent, but they last not 2,5-3 times longer.
I have 2 Honda's which are very reliable, but the availability of dealers and add on stuff is more limited than say Polaris.   I think I'd take a hard look at Polaris just because they are very popular (resaleable), many dealers, and easy to buy add on stuff.  Can Am didn't have the best reputation when I was looking 6 years ago, but they may be more reliable now.  Don't buy a full fixed windshield since you will probably need some ventilation.   My Honda 1000 with a full, fixed windshield, generates so much heat that I remove the doors for ventilation.
Enjoy whatever you choose...........
    • By Hugh
      Hugh
    • By Grizz
      Hello I have a 2022 axis 7004x4 Utv after about 6 months it would start fine but sometimes it would stall and you have to crank it again and it would run fine I am wondering what causes this does anyone else have this problem. Thanks
    • By Nickie Watts
      I have a Hisun Strike 1000 I have been trying to get going, it has only 39 hours on it, so I can only assume it has been sitting for a long time.
      The issue is it is losing spark to both coils after 20-30 seconds of running, doesn't matter if it's WOT or Idle, it will shut down.  What sends signal to the coils to fire? It has a crank sensor, I was thinking a CDI box, but I have not found one of those on the machine.
      The rear end was busted on it when I got it, So I ordered a new one and installed it only to run into this problem. I can only imagine the problem has happened over it sitting so long and not being driven.
      I originally thought it was a fuel problem, so I checked the injectors, throttle body, o2 sensors. Discovered the heating element in one of the o2 sensors was bad, so ordered both and also replaced both injectors just to be sure, then discovered it is only losing spark.
    • By moto mutts
      Exploring the Grand Canyon's Majesty at the North Rim UTV Fun Run
      Embarking on a journey to the Grand Canyon promises breathtaking vistas, but what we encountered during the North Rim UTV Fun Run organized by UTV Offroad Adventures was nothing short of awe-inspiring. The natural splendor we witnessed transcended our wildest expectations, leaving us in perpetual wonder.
      The weather was amazing! Upon our arrival at the Kaibab Lodge, we were immediately captivated by the serene setting. Nestled within a picturesque pasture with the national forest as its backdrop, this lodge was a true oasis. From the deck, where we savored cool beverages, we gazed upon the lush green grass and towering trees that stretched into the horizon. The experience was nothing short of breathtaking, offering a refreshing escape from the sweltering heat, and a chance to inhale the pure mountain air. And let's not forget the culinary delights that awaited us—mouthwatering food that was the perfect complement to the surroundings. As the evening wore on, the lodge became a hub of camaraderie, where stories flowed as freely as laughter. The Saturday night raffle event was a highlight, filled with lively exchanges and tales of the day's exhilarating rides.
      Speaking of the rides, both were nothing short of spectacular, showcasing the North Rim of the Grand Canyon's awe-inspiring beauty from every angle. It's a humbling experience to ponder the creation of this national monument, and it truly transports you back in time.
      We were joined by over 70 UTVs and 125 adventurers, all seeking the thrill of exploration amidst nature's grandeur.
      Bright Angel Point: A Scenic Marvel
      One of the rides led us to Bright Angel Point, renowned as one of the most picturesque spots on the North Rim. Sitting at an elevation over 1,000 feet higher than the South Rim of the Grand Canyon, this vantage point offered a mesmerizing panorama. To the east, the stunning Bright Angel Canyon unfolded, while to the west, Transept Canyon stretched majestically. Below, within the canyon, we could hear the roaring of Roaring Springs, a pristine source of water gushing from a cliff face 3,100 feet below the rim. The trails were a testament to nature's artistry, and each stop along the way was a spectacle in itself. This loop was around 80 plus miles and shared multiple astonishing overlooks.
      Point Sublime Trail: A Serene Oasis
      Our second ride took us to the Point Sublime Trail, a hidden gem known for its majestic views. This trail, less traveled by many, allowed us to enjoy the tranquility of the wilderness, punctuated only by the awe-inspiring vistas. It was a place of pure serenity, where the silence enveloped us, offering a chance to embrace the peace and quiet while savoring the views. Along the way, a chance encounter with a coiled snake added a touch of excitement to the experience, reminding us of the untamed beauty of the natural world. This loop was also around 80 plus miles with some of the best overlooks the Grand Canyon has to offer.
      Acknowledging Our Sponsors
      The success of the North Rim UTV Fun Run owes much to our dedicated sponsors, whose unwavering support ensures the continuation of these remarkable adventures. We extend our sincere thanks to Nash Powersports, Realty Providers, Rugged Radios, Shock Therapy, DRT Motorsports, Dirt Warriors Accessories, Kemi Moto, MRT Tires, McDermit Designs, Campfire Sports, Bob Moses Ceramic Coating, Gorilla Whips, Gorilla Offroad, Aftermarket Assassins, Rowley White RV, Memphis Audio, Factory UTV, Arizona Color Wraps, AJE Powersports, Macs Tie Downs, and a special acknowledgment to Shred 3D for their invaluable contribution as an event sponsor.
      A Date for Your Calendar
      For all adventure enthusiasts, make sure to mark your calendars and bookmark UTVOFFROADADVENTURES.com. Be prepared to sign up for your next off-road escapade, as these events unfold each month, promising thrilling experiences that will keep you coming back for more. If you seek further information about upcoming events, don't hesitate to reach out to [email protected]. We look forward to seeing you on our next adventure.
      The North Rim UTV Fun Run isn't just an event; it's an opportunity to immerse yourself in the awe-inspiring beauty of the Grand Canyon, share unforgettable moments with fellow adventurers, and create cherished memories that will last a lifetime. Don't miss out on this remarkable experience! This event is set for July 5-7, 2024.
    • By moto mutts
      This event will be limited to 30 UTVS Only; therefore, it is first come first serve. We recommend you sign up quickly, because spots will fill up fast.
      Click here to sign up or get more info
      The breathtaking White Mountains of Arizona are calling your name! Nestled at 7,000 feet elevation in the northeastern corner of Arizona, close to the New Mexico border, this is an ideal location for the off-road enthusiast thanks to cooler mountain temperatures and plenty of trails winding through pine forests.
      UTV Offroad Adventures presents the White Mountain UTV Overnight Experience. The mountains are filled with forests, calm lakes, and high peaks that will take your breath away. So, the White Mountains in Arizona aren’t just regular mountains; they’re a whole lot of fun waiting to happen!
      You will not want to miss this weekend filled with adventure! This event will take you on some of the most scenic trails Arizona has to offer in safe and organized manner. This is an EPIC overnight experience that will include your lodging and meals. The ride leaves from Eagar Arizona after a provided breakfast. Next, get ready for the beautiful White Mountain vistas and scenery as we head out on the trail to Hannagan Meadow, which is approximately 80 + miles. We will stay overnight at Hannagan Meadow Lodge. There will be a group dinner provided, raffles, quick draw poker, and lots of fun, laughs and good times. The next day will include a breakfast and then we will return to Eagar on some new trails. It is designed for all age groups and UTV experience. Come and see what we are all about and meet new and old friends. Join us in quick draw poker which helps us raise money for local charities.
