I had the Chinese car air cleaner setup - a little round car air filter with a bunch of blocked off hoses, and both the crankcase and transmission hoses run to the unfiltered side, so today i messed around with it a bit. I got a 2"ID silicone hose to mate to the carb neck, and ran it to a 2.5" to 2" exhaust reducer, then to a 2.5" 90* sweep and to a Uni Filter 2.5 x 6 filter. I put little breather filters on both the crankcase and the trans, and zip-tied them to the cage. Less than $100 bucks, and a real air filter to use in the dunes and dez. Might even enhance performance!
    • By SteveS
    • By tuell
    • By Robbie Wyre
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
