steering shaft
Kinarfi
The stock steering shaft has the outer hollow tube at the top and inner solid part at the bottom, has anyone reversed this and is there any reason why this couldn't or shouldn't be done? If I do it, it puts all my sensor up top instead of down under and makes it a lot easier to get too.
Kinarfi
I have seen them in upside down, and I don't think it makes any difference at all as to the orientation of the shaft.
Kinarfi
No difference.
    • By TPlummer
    • By A P
    • By Kingfish
    • By Chas
      When traveling in the 40 mph range and throttle is released machine starts surging instead of a gradual slow down any help would be appreciated as dealer is clueless
