Beryl
By LeMay624
Hey guys! Was wondering if anybody has had any experience in shutting up a Kioti K9 or Kioti Mechron. I daily drive a K9 in an underground mine and between the engine noise and belt whine I can’t hear myself think while driving this thing! 2-5 hours a day. It’s a 2021 model with 180 hours on it. Belt and clutches are clean, machine is maintained to factory recommended schedule and then some. Has been like this since new. Before I start boxing in the engine with plywood and stuffing insulation under the seat I thought I would reach out and see if anybody has run into this before!
By mark walkom
By diamondjfarm
Thanks.
By mac66
