Yesterday my Hisun Sector E1 stopped charging when plugged in. Anyone one have an idea of where to look for a problem?
Yes, I checked tht fuse. There is no power coming from the charger. There is power going to the charger, but nothing coming out! I am going to pull the charger and check it out.
Yep. Replaced the battery charger with a 48 volt charger from a golf cart. Found one on eBay. Works like a charm. Did not mount it where the old charger was mounted because it was difficult to get to so I mounted it in the area under the hood. I also cut a hole in the frounk for better air flow.
    • By hisun junk
    • By SouthernGypsy
    • By Justine
    • By se3388
      Steve.............
    • By Jacob E freeman
