Anyone playing with their Trooper this weekend?
By Kingfish
By hetovi
Hello everyone.
By Fishing Wiskers
By Chas
When traveling in the 40 mph range and throttle is released machine starts surging instead of a gradual slow down any help would be appreciated as dealer is clueless
By mac66
