hunnz, go to a good mulit-product ATV/UTV dealer and match up to a high quality USA boot. I found a Polaris boot that worked on my Trooper when I had to do a replacement. Then you can go an YouTube for videos of how change. All of my info, parts #, make and ect can be found in one of the pinned topics at the top of the Joyner forum page.
WE hope the factory starts using/making better quality boots as the ones on my Trooper are NOT of the highest quality.
rocmoc n AZ/Mexico
ok. We will talk this with the axle supplier and try to get some improvements of CV boots.
I see there is a design to add a sheet metal ahead the axle to protect the boots.
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
It is poor rubber chemistry which is causing them to go bad. As a matter of fact, every piece of rubber on my Trooper is cracking. I hope this has been addressed on your buggys.
I have asked Klung to look into some 4 piston front calipers which would bolt up to the Trooper. If we want to improve braking we either need more piston to compensate for excess volume being displaced by our current dual master cylinder set up, or a master cylinder/cylinders with a smaller bore to increase pressure.
  • 2 months later...
no,I don't think they are the same as the CVT belt transmission we using now .. we will show you the new transmission when it is availble .
Klung, any word on the CVT for the 1100cc Chery motor? I also sent a PM.
well. We checked with the supplier in the beginning of this month . THey says they still need two months . Sorry. It is a little strange .
Its worth the wait if it works the first time. Hopefully its because of all the extra R&D they are putting into it....or it is just taking an extra long time to reverse engineer :P
Guest Lenny
I just doubled up on brake calipers at each wheel and use the stock master cylinder. My braking is really nice now, never give stopping a second thought now where as before it was always like whooooa baby, are you going to stop.
Whooooa Baby,this is how i do it.
    • By aefron88
    • By SpaceGhost
      My vehicle is (at least not yet) not a UTV, however, it is an ATV, A 2001 Kawasaki Prairie 400.
      BTW, That's Brandy, my former PTS/TBI service dog on the bike. RIP old girl. She's internet famous. Perhaps you've seen her before...
      The reason I'm here is that Arthritis is starting to set into my wounds and my mobility is getting worse. I will be selling the quad bike soon, and going with a SXS, and have selected a Can Am model as the replacement, so I figured I had better get on board a forum somewhere. Just put in for my Guard retirement, and will be very soon looking to get into a Commander 6x6.
      Wouldn't mind having the Limited with the Hvac system, but am really not sure it's worth the extra 10 grand or not. Plus it's 500 pounds heavier, and I prefer the doors off in nice weather. It's so much easier when working in the yard, and so much more fun when on the trail.
      Anyway, I'm here now, so it will help me research more and make up my mind. Plus once I have it, I'll be able to share stories about it and of course, continue to learn more, as it will be my 1st sxs. Still have time before I get my retirement. Takes a good 90 days at least according to the guy I talked to... Typical government efficiency... lol.
    • By SouthernGypsy
    • By se3388
      Steve.............
