2018 Massimo 700 MSU Maximum RPM
By Jon V
Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
By lmarkie
I swapped out the Subaru motor for a Predator 670cc. If I remove the heat shield around the muffler, The stock muffler sits in there just fine with 1" to spare.
Only problem is the exhaust exit is toward the back seat instead of out the back.
Do you all think that the stock exhaust would be okay (just as effective) if cut a hole and welded a pipe on the reversed (opposite) end? Of course, plug the old exit end. Other option I thought of was to roll a tube 180° with a 7" center line radius and finish extention of 12" or so.
Any thoughts?
By Red Good
Serial # a8mv86futja001002 , no search engine will give me a model , it has a 471 engine . Is massimo always hard to get hold of ? No answer to emails or phone calls ?
By Brent4a
2022 Axis 700 overheating. We bled system several times, no luck yet. Weird thing is Radiator isn't getting hot and air coming into overflow jug. Doesnt seem like its moving water. Fan working fine, even wired it to turn on by switch. Only has 100 miles or so, just baffled. I am going to try bleeding more and see what happens. I did the head gasket test for fumes in the antifreeze, that was neg so far... Thanks
By Mike-Tatum
I have a broken item I’m trying to find the name for so I can order a new one. The gas line goes to the fuel injector. What is the piece that attached the fuel line to the fuel injector; “Y” shape.
Mike
