Does anyone know of a good replacement battery for a T2? Part #? Make?
Mine went dead (I think one of my kids left the key on) & I took it in to have it checked out at Autozone. As usual they said the battery is bad, but I am skeptical because they charged it in order to test it and it seems to be working normal. But, just in case...I think I might just buy a new one.
Edit-
Just found this post:
FYI,
Autozone stocks a direct replacement, 51-DLG. Exact fit, low maintenance, 3 year replacement - $95.00.
Randy.
Unless anyone has knows of any other options?
Guest Lenny
I use Optima marine batteries because they take the jarring better then any other. I get nearly 8 years on the Optima batteries in my truck. I mount it under the seat. Expensive though.
    • By Xov
    • By Gorj
    • By Grant
    • By SSgt1994
      Myron
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
