I have heard much mention of engine possibilities and auto trannys. What about a 2 speed transfer case? Do you think it would be possible? It would solve our low end torque issues. I haven't done any digging into the motor or trans. What have you guys seen? Out of the realm of possibility?
Guest Lenny
No room for a transfer case.
What we really need is some gear options for the trany. In one of my race cars that had the same configuration of engine & trans as the Trooper, I had the option of changing out the stock 5th gear with different ratio. We need a optional lower 1st gear. Just take someone casting a new gear, it isn't than difficult.
There was somebody out there 1-2 years ago making a higher 5th gear, not sure if it was No limits or maybe Silverbullet. We need maybe two more teeth in 5th and maybe 1 more in 1st.
I would like to do 55 at 4K rpm
Dick
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By SpaceGhost
    • By Bryan g
    • By dman66
