Noob welding question
Mopartist
I've welded on my Trooper many times before, but recently I was told I should unplug the circuits in order to keep from damaging the electrical system.
Would this be the place to disconnect on the red switch? :unsure:
I have always disconnected the battery.That way no chance anything may have been hooked up by passing the switch.
Guest Lenny
I would not leave the computer plugged in and preferrably remove it from the vehicle. I damaged one when I welded without disconnecting it however I was using Heli-arc in DC which initiates its spark with a high frequency spark to jump the gap. High frenquicy can easily kill a computer. Years ago, I developed some machinery that used a high frequency generator to cure glue in laminates. This machine was computer controlled and we had a fit at first with the high frequency getting into everything and blowing stuff. High frequency current runs on the surface of conductors and can jump around. It gets into everything and shows up as a spike in voltage. We ended up putting probably a hundred or so capacitors in the circuit to catch the spikes which solved the problem. I now remove my computer before welding even with MIG which doesn't have the HF. Fortunately I had extended insurance and they bought me a new computer.
Ehhhh.......so is the computer visable in the pic I posted? :unsure:
Guest Lenny
It's against the firewall behind the drivers seat. In your pic, it's about right behind the 2 white connectors on the lower right side of the pic.
Whoops ; I was trying to catch ya before you answered. I found out it was a plastic cover painted to look like the powder coated metal. :)
While you have the computer out, silicon all the way around it to seal out water, http://www.utvboard.com/topic/1834-trooper-computer-outputs-we-can-use/page__view__findpost__p__7396 2618386160104282158RlQWGL_th.jpg , the connector is a bit weird, you have to pry the loop to one side which lifts the plug away from the computer.
Kinarfi
    • By fishhouse3
      This machine is ready to go and needs nothing - just hop in and hit the trails!  I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
    • By Oldman
      Ive got an American Sportsworks BD-200.  I can’t get the ignition switch to work, but if I cross the solenoid, it starts right up. Runs great.  Can anyone send me a simple wiring diagram for a switch and where the 3 wires from the switch go!   Any help is greatly appreciated!!!   Thanks!
    • By htrotte
      #1   While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head  The two switches are literally 6 inches apart.  Does anyone know what this third switch is used for?  If i can figure out how I will post pictures.
      Author #2   Finally got the pictures took.  See the photo and tell me if you know what the switch on the right is.
      It looks to be factory and I know the girl who bought it new and she didn't install it.
      I can't find anything on it in any manual i have looked at.  Any help would be appreciated.
    • By htrotte
    • By todd93
      Hi, all! I. I'm new to the board, hoping someone could help me out! I have a 2020 Hisun Sector 550C that I bought new in 2021. Today, I took some stuff next door to my parents. When I went to leave, I turned on the key, heard the solenoid click, but no lights, no guage activity, no fuel pump, and no starter.
      The battery is good, I checked all the fuses, they are good. Not sure if the relays are good, or even what to look for there. Is it possible that it's maybe a wire?
      I'm really stumped on this one! Any help would be deeply appreciated! Attached is a pic of the fuse box layout.
      Todd
