IN 5 minutes, 2pm there is going to be a show on TV about dirtbiking near Hanksville in Cainesvale. About 18 miles West of Hanksville at somewhere called Swingarm.
Cainesvale is Mud Hills. Mud hills are just that, no rocks, smooth griping old mud that has dried into hills. They are great riding, hill climbing, jumping and doing trick stuff. The campground was just off the highway. No vegetation at all at this location. They are at a place called Swingarm City. Great single track location. I will have my dirtbike with me again at the Summer Jamboree.
rocmoc n AZ/Mexico
Guest Lenny
Hey Rocmoc, those trails look like a riot to ride. Now I want another dirkbike. I like trails that are more techincal and used to do all the hillclimb events for a number of years. By the way, I hope we will get a chance to see you do that double backflip you promised to show us. I did a quad backflip once but nobody saw me. Oh, that was after I hit the ground.
Len,
Only flips I do or have done were rolling on the ground. I love to ride mud hills. Always looking for a riding buddy! Like I said I will have my bike with me again this summer.
rocmoc n AZ/Mexico
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By Hugh
      Hugh
    • By Joe Breaux
      just an update on my MSU 500 . For all the misery it caused me the first 2 yrs, and the combination of some quality YAMAHA parts, it has now become a reliable ,useful UTV without the constant fear of having to push or tow it back from trails. I have not had a single issue pop up in a very long time.. FINALLY!....and as a side note, I just bought  a C FORCE 600 ATV to replace an old and well used  Honda that finally after 18 yrs gave up a rod bearing.  So far the new one has really impressed me .. I like the new Power Steering and  this CVT Auto Trans is new to me on an ATV .. I m used to constant shifting on my Hondas .  It also has something I have never seen. Its EBS  engine brake system, as soon as you let go of throttle, it engine brakes you to a stop rather quickly.. its great idea for the grandkids safety . Takes a little getting used to tho.. All in all, I like it. We shall see how durable it is after break-in.. I do "RIDE" them! .....and they honor their warrenty! and the dealer is 15 minutes away..
    • By Robert B
      Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
