More Camping in Utah
By aefron88
I've seen a number of requests for the location of all the grease points on these machines, and there is no definitive list in the manual. This covers the UT400, but other Coleman/Hisun models should be similar.
Tools:
First to grease your machine you need a grease gun and some NLGI#2 grease. You will find it helpful to buy a needle attachment as pictured here, due to poor clearance on some of the U-joints. The rest of the zerks use the standard attachment.
Technique:
Wipe any dirt/grease off the zerk before greasing to prevent pushing gunk inside and causing excess wear.
Push the grease gun on the zerk at a straight angle and give it a few pumps. You will hear an oozing noise or sea grease coming out from the outside of the greased area when you've put enough grease in, a few pumps should be plenty.
If it's just oozing around the zerk you either don't have a good seat with the gun, or the zerk may be rusted and the check ball frozen. Try seating it again and regrease.
Wipe up any excess grease when youre done to prevent making a mess.
Greasepoints:
Rear A-Arms are greasable with the wheels on from the rear, I took the picture with the wheel off for easier visibility
That's it. All other Hisuns should be substantially similar.
By Dreadnought
I've searched the forum but don't think I found a solution.
I just bought a used 2022 UT 400 with only 31 miles on it. Often I have to rev the motor just a little to get it to shift into forward or reverse. The original owner told me about this and said it needed the cable adjustment that you so often read about. It also jumped out of gear a few times and did grind a little but not very often and only under heavy load like going up a steep dirt road. After reading lots of posts I figured it must be the short shifter throw so I did the shifter extension modification. It didn't help at all. I thought, should I increase the idle speed? The tach reads about 1600 rpm at idle but it doesn't sound that fast to me. It doesn't seem like cable adjustment because it clicks right in gear with just a few more revs. Any ideas?
Thanks for any wisdom.
By MikeBiondo
Hello folks,
I would like to purchase some security lug nuts for the Axis 500, but not sure of thread size.
Anyone know the thread size and/or can recommend a product.
Thanks...
Mike
By Pat Dudley
Been looking at sport SxS for a while. Its against Can-am or Polaris. I'm not Biased. I want a turbo model for sure. I'm gunna be racing on my small bit of land with a few jumps. Then once a month up into the mountain trails where they are shared with 4x4 enthusiasts, the odd hiker and horse rider. So not too fast up there.
I'm looking at 2 used vehicles right now. One is the Polaris RZR Turbo S (2020) with 36hrs ; Light Bar Front bar Rear bar Rock sliders Mirrors Door inserts Door Bags Front half screen. Spare drive belt. Centre storage bag. Rear storage box. Spare wheel .1 other spare rim. About 1 year warranty to go Just had service
Other is 2017 Can-am Maverick X3 XRS (172bhp) 42hrs.Fully serviced . red/ gold loaded with extras. Front intrusion bar -Front bumper -Winch -Fender flares -Lone star rock sliders -Lone star rear bumper -Can am storage box -Side mirrors x2 -Roof -Led light bar -Metal gear shifter gate
At roughly the same price (can am is 5k more) its a tuff choice for me. Both brand new looking
Any views ?
By Travis
Well, any hunters around here? i assume so.
that time is closing in on us. Dove season opens 9/1, and white tail opens, 11/4, i believe,
The pigs are here year round tho...
More videos here, https://www.youtube.com/channel/UCujZlrZtdMkpeCqDForApPQ/videos , i plan on doing more videos of wildlife as well.
A destructive hog i shot last night.
