My intimidator is new less than 15 hours on it and it is overheating. Even on short rides less than 1 mile it overheats. Fan does not turn on at proper temps, checked relays and fuses and they check good. Any suggestions?
Bypass the temp switch .make fan run 100%..check oil for water in it. Look at recovery bottle while hot running for air bubbles.   Stuck thermostat.? Remove cap, see if coolant is circulating.? Water pump working?
    • By Smittay
      I saw that Intimidator is offering a $7k rebate on all their UTVs. This looks like an amazing deal. Are their UTVs any good? I looked through the forums and there appears to have been some problems in the 21-23 timeframe? Does anyone know why in the world they would be offering such a steep discount?
    • By Will D
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
