Guest Lenny
Hi all, I noticed that my antifreeze/coolant reservoir is low. It has the "green" solution. what brands do you recommend?
Any automotive antifreeze should be fine.
I agree with Lenny that any automotive antifreeze will do the job, but I have always believed in the 50-50 mix with distilled water, I usually use Prestone.
Guest Lenny
I agree, 50/50 mix.
If you still have the factory stuff in what I would do is drain it out and put in a good quality antifreeze, when I bought mine I replaced it with prestone 50/50 mix.
Depending on your local water, I always use a mix of 50% distilled water, if not available, I use RO water
    • By mark walkom
    • By Jeff S
      How to fix newer 800SX that gets stuck in LOW
    • By Paul Angstadt
      Paul
    • By diamondjfarm
      Thanks.
    • By Clint
      New to the side x side experience.  I bought a Coleman 550 Outfitter and I've seen conflicting comments about whether to use high or low range for running around under 15 mph.  Comments?
