husqvarna 4421
By SouthernGypsy
By Chucky 1
I purchased a new 2023 Landmaster UTV L4 in October of 2023. UTV didn't seem to have as much power of the demo L4 that I drove but figured once it broke in it would be better. After about a week the unit started bogging down backfiring and stopping. Gas fumes really bad, wait a few minutes and it would start up again. Brought it back to the dealer and after keeping it for a few weeks said he couldn't find anything wrong with it. Got it back home and it started acting up again, brought it back to dealer a week later and he said he found couple things that might cause it to do run bad and he was able to replicate the issue but didn't really know what was wrong. Got it back home again after being at dealer for several weeks and the unit started running bad again right away. Brought it back to dealer and he went back and forth with Kohler about possible fixes but just checked somethings and try to swap a few parts but still runs bad. I called Landmaster HQ to speak with someone about a refund and was told that was handled at the dealer level. Dealer called Landmaster and they told him they didn't do refunds or exchanges especially with units that had problems. The dealer is now trying to get a new engine to but I have not heard anything as of yet. I did file complaint with Better Business Bureau and they accepted my claim and reached out to Landmaster. The National Service Manager called me and said the he had been contacted by the BBB about the complaint and he would look into it. I told him that I would just like to have my down payment of $2,000.00 returned and never mind the over $1,000.00 I have paid in notes for a UTV that I cannot even ride on without hoping it gets me around the neighborhood. I have found out that the 2024 Landmaster UTVs will have Vanguard engines due to issues with the Kohler engines. Very disappointed in what is "Proudly Made in the USA" and the way Landmaster has treated this disabled veteran!
By redneckred
I have a 2012 Bennche Bighorn 700X. I bought it used. It had been sitting in a field for several years untouched. I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel). The machine cranked and ran beautifully. I had it over a year and then the machine quit running. As it would not stay cranked, I narrowed the problem down to a bad IAC valve. I replaced it and it ran as good as new/old. Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear. Then forward quit. I assumed a bad CVT belt and got one. Started removing the bolts from the cover and (3) just turn in the housing without coming loose. (2) are on the bottom, so very little room to do anything with them. I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank. It turns over fine. It gets gas to the injector and has spark. I can spray cleaner down her throat and she would run until it ran out. I have replaced the IAC twice and put a new injector with no change. I went out and put the old injector back in to see if that made any difference and, well, it did. I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off. I have to disconnect the battery to stop it. Before I shoot this thing, what am I missing? Is this an ECM problem or something else I am not seeing? Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving. I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful. Thanks in advance.
By Hutch
Okay everyone, need some help here. I got my 2014 Bennche Bighorn 700 from my father inlaw. He has had it since new and as far as I know never had any problems with it until recently. It began with it being hard to start and having to give it some throttle for it to start up. Then it wouldn't stay running once it did start. If you go to start it, it will fire right off and only run for a split second and then die. If you give it some throttle it will start and stay running as long as your foot is on the pedal. While it's running its pretty rough and backfires. Here is a list of everything I've done so far. Initially I checked compression and it was low. I changed the cylinder, piston and rings. Took the head apart cleaned and laped the valves. Checked timing a few times. Adjusted the valves. New spark plug. Checked the air filter, it was fine. New battery. Changed the fuel pump because of a broken fitting. Changed the fuel filter, lines and fuel injector. Dumped the old fuel and put new in. Changed the air idle control, TPS, MAP sensor, Voltage Regulator, ECU and harness. I was getting codes 31, 107, 113 and 122 on the display. Once I changed the ECU no more codes have been displayed but still have the same issues. All fuses look good and as far as I can tell Grounds are good unless there are some I can't find. I'm at a loss here. Not really sure where to go. Compression was better after everything I did but I don't remember the numbers. I'll have to check it again if someone thinks that could be the issue. Any help would be greatly appreciated!
