Public Campground Map / Site
By Chris M
I can shift into reverse and 'high' gear beautifully, but I can't get the UTV to go into low. I hired a mechanic to change the belt, and clean the clutches. When it came back 'low' gear no longer worked.
I tried to change I've tried replacing fan gears https://www.amazon.com/gp/product/B08V97JZL5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 that were worn down, and it shifts better but, didn't fix the low gear problem. I can't shift into low with the engine off either. It indicates that it's in low gear, but I hear what sounds like something spinning in the middle of the UTV.
It seems like the mechanic didn't know what he was doing. Never even mentioned it to me that 'Low' didn't work, until I went to use the
By Travis
I've always adjusted small engine idles by ear..... but i finally decided to buy a tachometer... it came in the mail today so i tried it out on the mule. it's the kind that wraps around the plug wire.
fire the mule up, the idle RPM spec in the manual is 1,300... and the way i have it adjusted now it was idling at 1,260, let it warm up and bumped it up to 1300, which wasn't much
By cliffyk
You never know how much you'll miss something 'til it's gone...
Advise your hosting service to install a dry (argon/halon) fire suppression system. 99.44% of the time with wet systems the water does more damage than the fire--this is true in almost every industry, but more so in server rooms.
-cliff-
