Recently helped 66fastcarss with his Trooper and I drilled and tapped the tops of the ball joints for zerks, on mine I did the same and welded the tops back on. When I greased them, the grease would ooze out the top. On 66fastcarss', I used JB Weld and made sure I used plenty so the threads were well sealed, after it cured, I applied grease and none of it oozed out the top, I think this may be the way to go. Did NOT add any welding as I thought the heat would destroy the epoxy.
i saw your post on upgrading your ball joints to accept zerk fittings and thought you or somebody on the board might be intrested in our ball joint "upgrade" kits offered here at silverbullet. they consist of 90deg zerk fittings for ease of greasing, polyurethane boots to resist corosion from the sun, and a set of clamps to hold it all in place. we are under new management and are striving for better customer service and faster turn around time. thanks 928-344-2117
      Is there a diagram of all of the grease zerks for a Coleman UT 400?  Mine squeaks like crazy and want to try and remedy it.
    • By allinone
    • By Ken rung
    • By rocmoc
      rocmoc in AZ/Mexico
    • By Brent C
      Hi all, I own two Axis UTV's. Last year I purchased a 2022 Axis 500. I had a mechanical issue with the shifting forks after only 50 miles. I contacted Axis/Hisun warranty dept. That were very helpful and willing to send out a representative to see if it was a warranty issue that fell under coverage.  Since I live in an area that does not have authorized repair facility within 300 miles. A really nice guy drove all the way from West Virginia which was 4 hours away. He determined that the console would not stay seated in position and while driving it, the console would jump forward and knock it into the wrong gear causing the shift forks to become bent. It was then picked up a few weeks latter to be repaired in Richmond, Virginia. It should arrive home soon.
      Now to my question. After the 2022 Axis 500 was taken for repairs, I bought the 2024 550 Axis. I bought the first one to take my son who is disabled from an extremely rare disorder that requires daily care to get out of the house. There are two things that give him joy, music and going for rides.  That is why I purchased the first one, However because it had bucket seats and the engine was between the two and was too loud even though I deaden the sound and put a quiet muffler on it.
      I then decided to purchase the Axis 550 for the great updated features and the bench seat, I will be buying the complete enclosure ad on's offered by Hisun. Since it does not come with a heater (Axis 750 does) I was wondering if anyone knows what heater is part of the 750 edition. There was a photo that showed a Firestorm brand, however I can not find what variation it is. If anyone knows what a Inferno heater would be correct for the Axis 550. I would like to install it this Winter to take Justin riding on the farm. Any help would be greatly appreciated.   Brent
