I have a 2019 hi sun 750 I parked it in my garage last fall and about a month later I went to ride it and I had no power but the battery shows good. I’ve taken the ignition switch out and cleaned it. I cleaned the battery terminals and replace the main relay all my fuses are good. I still show strong battery but get no power, can anyone help or have any ideas? I have yet to find any wires chewed up like from a mouse or anything all the wiring looks good.
  • Alex changed the title to 2019 Hisun 750 No Power
I’ve tried to jump across the solenoid and all it does is turn over no power to the dash any of the gauges or any of the equipment on it like the winch or hazard lights I don’t see any wires chewed up I’ve replaced the main relay and the ignition switch.
    • By Gerald Mohs
    • By BigWave
      Bigwave
    • By GunnersTacklebox
