2019 Hisun 750 No Power
By Goat Quilter
We pout new belts cleaned engine and carburetor plugs you name it. Drove down road no problem came back uphill no power won’t go . What’s the issue?
could it be clutch?
By hisun junk
I have a 2018 cub cadet challenger 750 with a broke chinese hisun motor and I know that I'm not alone! Almost all the places that were selling them in Colorado don't anymore due to the return for repairs on the clutches and broken timing chains! Don't have yours fixed because it will happen again! They just replace the broken parts with more junk chinese parts! I talked with a UTV mechanic that has replaced one person's clutch 4 times! I have people contacting cub cadet about these problems and also looking into complete motor replacement from hisun junk to a Japanese motor in which the chinese cloned their junk from.
By Goat Quilter
New belts and engine cleaned and checked carburetor cleaned drove on flat ground fine turned to go up hill lost power wouldn’t go
Could it be clutch issue??
so frustrating this thing has been in shop more than used on our farm.
By jonny L
Went for a nice trail ride for about 20 miles, came back, shut it off, and attempted to go for another ride. The electronic gear shifter will not go into park to start it up. It reads neutral in the park position. Disconnected the battery and reconnected and it now read Park. But, when you put your foot on the brake to start it, it goes right back to neutral. Checked everything that I could think of and decided it has to be the 17 gear position sensor. Not certain this is the issue but I bought a used one on Ebay (could not locate a new one) and will try it. Any other possibilities?
By amiracle40995
I've never seen the temperature go high on this thing. the fan runs almost all the time even though the sensor is reading at the very bottom of it's range. ive taken the cylinder head off. (nothing definitive but maybe a little fuel on top of piston with oil in it.i don't think this has anything to do with my problem )head gasket is 3 layers deep and I noticed some grit that might have been in between layers but nothing to say the head gasket wasn't intact. black carbon build up on piston. I've looked all over the head for cracks from over heating. I'm about to look again for hairline cracks that are extremely difficult to see. my buddy helping me said to order rings in case they are letting oil pass thru he also said get a new head gasket.. I'm looking at water in oil first and I'm not ordering rings. I haven't checked the oil cooler to see if it's defective yet. I'm just hoping someone had a similar problem. my only problem so far has been having to change the spark plug every 100 miles with 93 octane run thru it.
