Lost track of just how small it is getting
Guest Lenny
Watching Mad Money and just learned something about computer chips that seemed worth repeating. A millimeter is aprox. .039" and a nanometer is .000039". Human hair is aprox. 50,800 nanometers, the smallest bacteria is 50 nanometers. the smallest virus is 20 nanometers. Intels chip circuits are 3 nanometers. I'm just getting too old, I can't seem to comprehend that.
Tell about it, I order a chip to make a 12 to 18v converter and it was so small, I ruined it by breaking of several leads trying to use it, so I order some samples from another source and they were even smaller, They're still in the bag and in storage, no way can I use them until I get a microscope to work under :angry::blink:
I did get a 12 to 60 volt converter working so I can drive some 10Watt LEDs, but I blew them up and have more ordered, hope I get them and have it working for jamboree
      Best way to reset the computer?  Can I just disconnect the battery for a few or do I need to do something else?
    • By NC4wd
      Has anyone installed the magnum tuning chip? Is it worth it? Noticeable difference? I have a 2021 Axis 500.
    • By Kingfish
    • By diamondjfarm
      Thanks.
