Lost track of just how small it is getting
Guest Lenny
Guest Lenny
Watching Mad Money and just learned something about computer chips that seemed worth repeating. A millimeter is aprox. .039" and a nanometer is .000039". Human hair is aprox. 50,800 nanometers, the smallest bacteria is 50 nanometers. the smallest virus is 20 nanometers. Intels chip circuits are 3 nanometers. I'm just getting too old, I can't seem to comprehend that.
Tell about it, I order a chip to make a 12 to 18v converter and it was so small, I ruined it by breaking of several leads trying to use it, so I order some samples from another source and they were even smaller, They're still in the bag and in storage, no way can I use them until I get a microscope to work under :angry::blink:
I did get a 12 to 60 volt converter working so I can drive some 10Watt LEDs, but I blew them up and have more ordered, hope I get them and have it working for jamboree
    • By Kingfish
    • By diamondjfarm
      Thanks.
    • By Robert B
      Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
    • By Greg Kilgore
      We all know summer is hot inside the cabs of our SXS. So I've rigged up a couple of fans to help cool down the cab.
      I didn't want to drill the fan's "support rails" into the ROPS (Roll Over Protection System), aka roll bars. So I used water clamps to hold them in place.
      I just need to replace the wires I ran with bigger gauge. Then finish the wiring to switches, relays, and battery. But the hardest part. The actual mounting of the fans is complete. Also just in case anyone plans on doing this. I may have to only use 1 fan in the middle instead on 2. Due the the draw on the battery.
      The fans are 12", 12V 80W. So I'm figured they were 6.7 amps apiece. Used the WAVe formula to get unknown values Watts=Amps*Volts then solve for unknown. I know the watts and volts from sticker on fan. So just used above formula to get amps. So a 7 amp fuse should be OK and a 10 amp fuse will be good.
      So pulling 14 amps from the battery all day may be too much for the charging system to keep up with. And I haven't even installed the radio yet. So I will have to test and let you know.
      See pics below.
