  On 6/26/2011 at 12:45 AM, plumber said:
Rick, How are the instruction coming taking the trooper to the mechanic wednesday to get the valve lash measurement you need. How much does a new timing belt cost Thanks
hey plumber,
we are working on the instructions as i type hopefully will be completed today and typed up tomorrow with detailed pictures on the process thanks for your patience
Jose
Silverbullet Motorsports
  On 6/28/2011 at 4:54 PM, silverbullet said:
hey plumber,
Jose
Jose,
So are you the contact now?
  On 6/28/2011 at 5:07 PM, ricksrb said:
Jose,
hey rick
yes i will slowly become the contact, for now its me and rick still. i will also be handling the parts and looking over the shipping dept to make sure orders are being processed efficiently.
  On 6/28/2011 at 6:48 PM, silverbullet said:
hey rick
okay thanks.You have the trooper brake pads? How much a pair?
yes we have both OEM brake pads for 24.95 a set and also have the sintered iron pads for 49.99 a set
okay,will call you tomorrow.
Just beware the more aggressive a pad is the more the rotor wears. I use to have to replace my race car rotors every other year from the aggressive pads we ran.
rocmoc n AZ/Mexico
rocmoc n AZ/Mexico
We have been using the sintered metal pads for about 1year or 1,000 miles and no big rotor wear.They are great on my renegade we don't use the brakes much.But when you want to stop they stop.We use synthetic break fluid stops faster and it takes the heat.The hotter they get the better they work.We are going to supercharge my Rengade first.We have a customer who we are going to work with on his trooper to supercharge his.So we are going to work on both of them at same time.Lenny is the one who started this whole thing.Now we are going to see what we can do with this set up and keep the price down to be affordable.
Cam shafts shims and installation instruction are all most done.Plumber we are going to ship out your cams soon cant wait to see what you think.
Rick
Rick
I'm ready I been playing with my fuel controller and I have bought a air / fuel ratio gauge I will be installing this weekend
Guest Lenny
This should start to get exciting with others moving forward on engine mods. I should have tuning tables for you Rick (SilverBullet) soon plus I have the belt sizes needed to run my setup. If next years Jamboree is at Glammis then hopefully you will be able to make it.
    • By Grant
    • By A P
    • By clint501
    • By staind
      thanks Dan D. aka staind
