Rear wheel bearing gone bad
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Eagle Mountain Outfitters
By Paul in Wisconsin
I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
The service manual shows how to remove and reinstall the sway bar.
I called Cabela's to try and get the saw bar. They said they can't get one and the 800SX doesn't have one!!?? Then why is it listed in the service manual?? No answer from them.
Have any of you found a saw bar that fits and what did it cost?
By Josh5696
By TPlummer
