  • 5 weeks later...
Not sure of what you  need,  Are you talking about the rubber sleeve on the pump?  If so I cannot help you but You might try contacting the sellers on eBay they might help you.  Sorry I shouldn't have responded.
I am fighting a fuel pump problem.  I have changed everything, Pump , Regulator, Filter It will start run any where you want to go.  Park it turnit off and the fuel pump will not come on due to low voltage.  Any on have any ideas?
yes Battery is good and it is charging.  Mine is a 2008 Tracker and it was funny changed pump drove it and parked it.  Next day fuel pump not working no voltage to pump.  Found a relay that no one knows any thing about shows a picture of something in the manual;, but no item number.  There is also two fuses that are no listed in the parts manual.  The maintenance manual I have for this unit has a publication of 2006.  My unit is a 2008.  Things sure changed.
I'm Sorry I said I could not help you I may have lied to you.   I have a foam rubber wrapping that came on my old pump.  The rubber is still usable if you need one.  Let me know.
    • By Mike Jenkins
    • By Chile
      Chile
    • By Ed Michael
      Subaru SxS.mp4
    • By Some random dude
      2015 Hisun 700 Utv
