2016 cub cadet challenger efi fuel pump
By Jon V
By corkie
I have replaced the fuel pump assembly 3 times in the last 3 years. The motor always goes bad and will not come on when you turn the ignition on. Anyone else having this problem?
I have a Hisun utv 500.
By weasel
By hisun junk
I have a 2018 cub cadet challenger 750 with a broke chinese hisun motor and I know that I'm not alone! Almost all the places that were selling them in Colorado don't anymore due to the return for repairs on the clutches and broken timing chains! Don't have yours fixed because it will happen again! They just replace the broken parts with more junk chinese parts! I talked with a UTV mechanic that has replaced one person's clutch 4 times! I have people contacting cub cadet about these problems and also looking into complete motor replacement from hisun junk to a Japanese motor in which the chinese cloned their junk from.
