i had 01 kaw praire got rid of it then moved up to the big mother, being in the us do u have to buy a trail pass & do u get hounded by the bacon ''cops'' ?
We, in AZ, have to buy a annual off-road pass. This is becoming the norm in most of the Western USA. I am remote enough that I rarely see any kind of Law Enforcement with the exception of the Border Patrol.
    • By Xov
    • By Howard Elmore
      I have owned mine for a couple years now but newer took off road.  How well does it do trail riding m?
    • By Kingfish
    • By hdtran
      That's the question! Or, if you want to add details:
      (a) How do you use the UTV? (roads? off-road to get to trees? etc.)
      (b) If you are wearing a helmet--how frequently? What type of helmet?
      My own answers: (a) Most of the time off-road to get to downed trees, cut the trees to logs and haul the logs back for splitting. (b) Very rarely, a ski helmet and not a motorcycle helmet.
